Archived from groups: alt.sys.pc-clone.dell (More info?)
You should have a drivers disk that came with the laptop if you run that and
then navi=gate to the drivers window it will put a tick by each driver you
need for that machine, in saying that if you have formmatted the drive you
will need to install the chipset drivers 1st otherwise other parts will not
function correctly
"less" <lesstif@nospam_hotmail.com> wrote in message
news:cvim47$nah$1$830fa7a5@news.demon.co.uk...
>I have Latitude D600 and built in truemobile 1300, need WPA so which
>drivers (UK) do I need.
> I tried R90507.exe but it failed to install
> is this the correct driver
> anyone else had problems?
> less
the drivers that came with it are installed and working! i dont have WPA
support. I will try the windows xp WPA update (as i have not installed the
updates yet), see if that will give me WPA support, however, i think i may
need to install a updated driver from dell's website.
less
"Fixer" <steve@kelly90.wanadoo.co.uk> wrote in message
news:cvippp$9gb$1@newsg4.svr.pol.co.uk...
> and then navi=gate to the drivers window it will put a tick by each driver
> you need for that machine, in saying that if you have formmatted the drive
> you will need to install the chipset drivers 1st otherwise other parts
> will not function correctly
