G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have a Gigabyte MoBo-GA-8LD533, Intel 845GL Chipset, Celeron 2GHz w/ 400MHz
FSB and 266MHz Mem Speed running Windows XP Home Edition. I've been running
512MB of DDR ram. I recently purchased 2 512MB PC3200 DDR sticks, intending
to upgrade to 1GB. I purchased 2 sticks for a matched set.
THE PROBLEM: My MoBo has 2 DIMM slots capable of using 1GB sticks each. When
both slots are populated with any 2 of the DIMM sticks, it hangs or crashes.
WINDIAG (Microsoft memory test program) also hangs at random, sometimes
running through several complete passes, sometimes right off the bat.
HOWEVER; when ANY of the three 512MB DIMMs are inserted into EITHER of the
DIMM slots with the other empty, system runs fine, and MEMDIAG will run all
night without a glitch. I'm no newby to computers, but I'm at my wits end. I
even re-flashed my BIOs to the newest revision, again.
MY GUESS IS; I've got a flakey memory controller, and therefore I'm stuck at
512MB MAX, or a new MoBo. However, I thought maybe someone out there might
have a suggestion or two that I haven't tried. Anything come to mind??
