Hi , I've recently purchased a 9800 pro video card and is having performance issues. Compared to my old Geforce 3 ti 500 it performs slightly better in Direct 3D games. However , when it comes to open GL games such as Counter-Strike , the 9800 pro is significantly slower than my old geforce 3 ti 500 card , frame rate wise. Using the 9800 pro I get tons of slow downs , while my geforce 3 ti 500 gets almost none.
Could this be a settings problem or is it because of the video card? Or is it because my Nforce mobo doesn't run well with this video card?
I've got all the latest updates and drivers.
Please help , here's my system specs:
AMD XP 2000+
Nforce Asus Ultra mobo ( 4X)
512 DDR Ram
Windows XP pro
It is urgent that I have to return this card as soon as possible if there is a problem. So please reply as soon as you can. Thanks in advance.
AMD XP 2000+
512 DDR Ram
Windows XP pro
