G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
My Indy game does not have any sound. I have turned on the test mode
and when I get to the sound check it says, "Sound Processor not
responding", or something close to that. I have looked through all of
my books and can not find the sound processor. I did pull out the
sound board last night and looked it over and I could see nothing wrong
with it.
I have owned the game for 10 years now and it never gets turned on
much. The inside is very dusty now, I tried to clean off the dirt as
much as possible with some dry paper towels. I didn't see anything
wrong with the sound board, but I really don't know what I'm looking
at. I can see if something is broken, but other then that I'm at a
loss. I haven't pulled the other boards because I wouldn't know which
of the two to take out and I don't want to do any damage.
I did check to see if all the wires were snug, and things like that.
The rest of the game works fine.
Can it be all the dust causing problems? I noticed a lot of it and I
guess it could get into the connections. How would I go about cleaning
off the boards. I figured that water would be a bad idea.
Where can I find the sound processor so that I can get Indy back up and
running properly?
with it.
running properly?
