Archived from groups: alt.sys.pc-clone.dell (More info?)
During installation of a program I get the message:
"GLJ2.tmp has encountered a problem and needs to close"
How can I find the source of the issue and hopefully fix it?
Details:
This program was previously installed and worked fine for a long time until
I recently uninstalled and tried to reinstall..
The same file works fine on another PC.
This is a DirectX program.
I have XP SP2, DirectX 9, Dell Dimension 8200
What I tried:
I have tried starting in every compatibility mode...w/same result.
I have tried to install during Safe Mode...same result.
I have stopped all firewall, virus, worms scans...same result
I have successfully installed on another PC w/XP SP2.
I have done a system restore to a week earlier...same bad result.
I must be something that is configured on my PC that I hope is easy to
change, since it works on the other PC.
Any tips appreciated to trouble shoot and hopefully find a solution.
"How can I find the source of the issue and hopefully fix it?"
By contacting the technical support people at the organization that wrote
the program.
Ted Zieglar
"jtsnow" <jtsnow@yahoo.com> wrote in message
news:XCBTd.4561$Az.2977@lakeread02...
> Details:
> until
> What I tried:
> Thanks
