G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Does Rev A have 'Rev A' anywhere on the board or is it just blank? My serial
# is in the 36xx range.
Mine does not have any revision printed on it.
On the LS02 at location A2, does it have a wire wrap mod? On mine, two
traces are cut, and the wire wrap soldered so that they are swapped. Did
someone just fix some damage and goof it?
My symptom is that there is no playfield either in test or in game. Also
some of the colors are wrong.
I have a service bulletin I need to put in for google and here it is:
System 1 TTL REV A to REV C MOD
Without this mod, the TTL Main will not run Roadrunner or Roadblasters
program cart.
1 . Cut and lift 14M pin 6, connect this lifted pin to 14M pin 16. (+5V).
2. Cut and lift 3D pin 11.
3. Connect 3D pin 13 to 4A pin 5.
4. connect 3B pin 13 to 4A pin 6.
5. Connect 3B pin 12 to 4J pin 12
6. Connect 3B pin 11 to the PAD of 3D pin 11.
Not responsible for typos but I read it a couple of times.
"Quality is the enemy of production."
Homepage - http://members.cox.net/rcbullock/ 'It's lamer than Spaeth's!'
** Replies to rcbullock '"AT"" cox.net ** Sorry, I detest spam.
program cart.
