I just built myself a new PC, and I'm having a big problem with my old monitor. The monitor is a Mitsubishi Diamond Scan 91, which happened to work fine last week on my old Win2K machine, and it's one I'd like to keep if possible. The problem is that on any resolutions above 800x600, it shows lots of ghosting and blurriness, particularly on text. It's quite painful to look at for any length of time. Changing the refresh rate has no effect.
Here are the specs for the new machine:
Abit NFS7-S
Athlon XP 2500+ (not oc'ed yet)
Corsair PC3200 1x512Mb
MSI GeForce4 Ti4200 AGP 8x
Segate 7200.7 160gig
Windows XP Pro, SP1
I think I've isolated it to a problem with XP. Sticking my old Voodoo 3 card in the machine revealed the same ghosting problems, so I don't think it has anything to do with the new Ti4200. I've tried updating the monitor drivers, even trying ones for different Mitsubishi models, all to no effect. The machine boots and runs like a champ otherwise.
Anybody have any suggestions about what else to do? Or is it time to start shopping? Thanks.
Abit NFS7-S
Windows XP Pro, SP1
