Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Advanced System Info prob
Forum Windows XP : Windows XP General Discussion - Advanced System Info prob
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello everyone,
Start-All Programs-Accessories-System Tools-System Information
When running I get in the right hand side where information should be -
Cant collect information.
Cannot access the Windows Management Instrumentation software.
Windows Management files may be moved or missing.
Anyone got any clues to help with this one please.
p.s this one is without the screen picture.
Sponsored Links
In news:427f35cf$0$5176$afc38c87@news.optusnet.com.au,
C&S-M <cgsam(remove this)@optusnet.com.au> had this to say:
My reply is at the bottom of your sent message:
> Hello everyone,
> - Cant collect information.
Start > Run > type "services.msc" without the quotes > hit enter
Start (set to automatic) Remote Procedure Call and Windows Management
Instrumentation services.
If those are already started then you may be needing to open the control
panel, click on admin tools, component services. Dig down to DCOM Config
under Component services, find and right click on WMI, select properties,
and then under the security section set it to allow for your user or user
group.
Galen
"And that recommendation, with the exaggerated estimate of my ability
with which he prefaced it, was, if you will believe me, Watson, the
very first thing which ever made me feel that a profession might be
made out of what had up to that time been the merest hobby."
Sherlock Holmes
Reply to galen
There are 651 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
