Tom's Hardware > Forum > Games General > Games General Discussions > vertical hold problem and no sound
Forum Games General : Games General Discussions - vertical hold problem and no sound
Archived from groups: rec.games.video.arcade.collecting (More info?)
hello everyone. i'm new!
i bought this street fighter cabinet and decided to swap out street fighter
with streetfighter 2 CE. i got the sf2 PCB and tried to swap it out but the
harness didnt connect right. i had to lie the cabinet down on its side so i
could adjust the harness to get the new board to fit. now that i got it in
and connected up there is this horrible vertical hold problem. the image
keeps dropping, and doing it pretty quick. there also isnt any sound.
since im new i dont know what to do. i was thinking there might be a
vertical hold adjustment on the monitor but i dont want to go touching it
without knowing where to touch. i really am lost and would appreciate as
much help as possible.
thank you
denny
Sponsored Links
ok, so i found the vertical hold nob on the monitor and turned it and the
constant scrolling got worst, i then turned it the other way and it got
better, no more scolling screen. but the picture still wasnt right. i
adjusted
the horizantal position and the brightness and the picture got better, but
still not quite right. so i adjusted the horizontal position, brightness,
and contrast just a little bit more and now all i get is a white screen. the
only things i can make out are the burnt in spots from the street fighter
game that was in it before. i moved the nobs back, no difference at all. i
moved then all one way, then the other, and still nothing. did i break it?
can i fix it? i dont know.
please help
"Jason Denman" <denny1824@nc.rr.com> wrote in message
news:x0vfe.20148$Fa.633459@twister.southeast.rr.com...
fighter
the
i
> thank you
> denny
Reply to Anonymous
What's the make/model of the monitor?
news:h3Qfe.27039$Fa.811895@twister.southeast.rr.com...
> adjusted
> the
> please help
> fighter
> the
> i
>> in
>> thank you
>> denny
Reply to Anonymous
well, the tube says Philips ECG MVA48BKO5X and there is also a sticker on
monitor that has the MVA48ABKO5X and a sticker that has a circled SA and
then LR 41155. I dont know what any of that means or how to tell what really
is the make/model of the monitor.
"Steve Muccione" <home*DOT*muccione@verizon.net> wrote in message
news:azQfe.3832$w56.2468@trndny08...
Reply to Anonymous
ok... NOTHING on the tube means anything... we need to know the actual model
of the "chasis" which is the circuit board... something that says 4900,
4600, G7, etc. see anyting like that?
news:vISfe.11544$tf1.889437@twister.southeast.rr.com...
> really
Reply to Anonymous
the only thing i can find on the chasis that doesnt seem to be labeling just
a part of the circuit board is P447
news:KcUfe.4064$f57.2100@trndny04...
model
on
> > really
Reply to Anonymous
- 0 +
That's a wells-gardner k7000 This link might be helpful to you:
http://slot-tech-ftp.serveftp.com: [...] 000flo.jpg
My board looks practically new, but I have had several problems with bad
solder connections. I've had to reflow solder to several loose locations to
get the monitor working again.
news:iLage.24915$tf1.1103029@twister.southeast.rr.com...
> just
> model
> on
>> > and
>> > really
Reply to terry
humm... sounds like something went south on you.
A couple possibilities:
1. IC1 went bad
2. VR6 went bad
3. VR7 went bad
Since you were fiddling around with VR6 & 7 at the time it stoped
functioning I suspect that one of the sweepers on the brightness or contrast
pot is now an almost-open (probably around 500K ohms or so) instead of the
nominal 2K ohms.
You're probably going to need to replace one or both of the pots.
Do you have a soldering iron and an ohm meter. It's easy enought to remove
the part and test the resistance at a few sweep positions to verify if it's
still good or not. At least if it's broken it's only a $1 part (plus $6 in
shipping if you get it from bob roberts (sigh... like i've never done THAT
before :( ).
Does someone else know if an open brighness pot will drive the display white
or dark on a K7000?
steve
> just
> model
> on
>> > and
>> > really
Reply to Anonymous
There are 541 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
