Samsung laptop wifi problem
My samsung laptop NP300E5Z-A02AE is giving problems while using wifi it takes ages to try to connect to any network while others use that network smoothly.And internet works fine on LAN
WHAT SHOULD I DO to Solve this issue
thanks in advance
3 answers Last reply
More about samsung laptop wifi problem
  1. Go to Samsung's site and see if there are updated drivers, or try and reinstall the existing drivers.
    What wifi module is it?
    i dont know the module but if you mean model then it is intel centrino wireless n130
  3. Go o Intel's support site and download the drvers from them. They will have more updated drivers than Samsung will. I think Intel has a automatic drier updater you can try too, but if it doesn't pick up the wifi, download it manually.
Laptops WiFi and Home Networking Samsung
