Archived from groups: alt.sys.pc-clone.dell (More info?)
visit support.dell.com and select your inspiron 7500 model and look under
documentation and then 'removing and replacing parts'. it isn't a highly
detailed diagram, but certainly enough to help you discern the different
components and how to remove/replace them.
http://support.dell.com/support/ed [...] moving.htm
<David Ellis> wrote in message
news:lj1521thi50o9l8eav3v2rpfajsu1sgn6n@4ax.com...
> I've seen the web pages that show parts explosions and provide a way
> to order but can't find it when starting with www.dell.com. > --David
Thank you. Any idea where parts can be ordered?
>http://support.dell.com/support/edocs/systems/psyd/removing.htm
>> to order but can't find it when starting with www.dell.com. >> --David
first, try dell spare parts division technical support can give you their
number and you really have to speak with technical support to obtain the
exact part number for the item you need... the spare parts division only
enter orders and can not help you identify part numbers. you will also find
that most parts found in the system have a dell part number on them (though
the part number may have been replaced with a newer alternative substitute
part and part number). dell parts, other than motherboards, are very
reasonable and come with a 90 day warranty, 30 day return policy (so if the
part dosen't help you can return it). however, given the age of the machine
they may no longer carry parts for the system. otherwise you can try
ebay... just be careful that you are purchasing from a reputable seller (do
you homework). and keep in mind that a fast inspiron 1150 can be had for
about $600 (so don't invest too much into this older system). good luck.
news:f20921h4k58loi3lo3clqa4r7ir3t44g5b@4ax.com...
>>> to order but can't find it when starting with www.dell.com. >>> --David
OK. Thank you for the thoughtful and comprehensive reply.
>>>> to order but can't find it when starting with www.dell.com. >>>> --David
news:2mrb21pp1asts6dhdb2a63eflioq8feir4@4ax.com...
find
(though
substitute
the
machine
(do
<snip>
