Yes No
Ads
Tom's Hardware > Forum > Wireless Networking > General Discussion > Connecting to wireless with a cable?
Forum Wireless Networking : General Discussion Connecting to wireless with a cable?
Archived from groups: alt.internet.wireless (More info?)
Hi,
Yes, sounds weird. Like the reverse of a WAP, I guess. I have an
older Windows 98 desktop that I want to hook into the wirelss network.
Instead of installing newer cards that may or may not work with the
OS, or upgrading the OS, I just want an access point that I can plug
the LAN line into that then hooks me into the wireless network.
What's the term for what I am looking for here?
Thanks!
oj
Reply to Anonymous
You want an Access Point that features "Client Mode". I would bet most, if
not all APs these days support this. A Linksys WAP11 will do this.
Connect directly to your PC via a Cat5 crossover cable (although this
doesn't seem to work on all combinations of ethernet devices, you may need a
hub as a go between)
-- Paul
"OJ" <orljustin@aol.com> wrote in message
news:77d3a68b.0404040603.33650097@posting.google.com...
> Hi,
> Thanks!
> oj
Reply to Paul
orljustin@aol.com (OJ) wrote in news:77d3a68b.0404040603.33650097
@posting.google.com:
A switch/hub.
Lucas Tam (REMOVEnntp@rogers.com)
Please delete "REMOVE" from the e-mail address when replying.
http://members.ebay.com/aboutme/coolspot18/
Reply to Anonymous
Or Wireless Bridge.
Reply to Anonymous
Lucas Tam <REMOVEnntp@rogers.com> wrote in message news:<Xns94C1A460AD596nntprogerscom@140.99.99.130>...
> Or Wireless Bridge.
Hi,
This seemed to be actually what I was looking for. The Linksys WET11
I think.
However, once I unpacked my old puter, I realized I didn't have a LAN
card. I have Windows 98 running. The only options I could find for
Windows 98, at least as listed on the requirements on the net, were a
Microsoft PCI card MN-730 and the Microsoft USB adapter. However, on
the box, the USB hub said Windows SE. Gave it a try, but no power
went to the adapter, so I guess it wasn't recognized by 98.
Finally got the PCI card in and running, after many crashes, tech time
with India (Hi, my name is Mike .. right ...useless), and finally
realizing it was conflicting with ZoneAlarm. However, the 98 version
does not use WPA, which I thought I might have a problem with. So out
I go today to get an upgrade to XP for my ole PIII 700mhz and hope
that this will work to get this thing on the net.
Thanks.
oj
Reply to Anonymous
>> Or Wireless Bridge.
>Hi,
>I think.
>Thanks.
>oj
Since you are upgrading to XP, and you need to install an ethernet
card to use the wireless bridge, why not just make it simpler and
install a wireless PCI card such as the WMP54g? It will be probably
be easier and work better than a separate USB adaptor.
Reply to Anonymous
wireless user <flupflup@nubnub.net> wrote in message news:<kqr2709bndut1au6qmtqtjebpuqm01ucof@4ax.com>...
> >> Or Wireless Bridge.
> >Hi,
> >I think.
> >Thanks.
> >oj
Hi,
Yep, that's what I'm doing. Keeping the MN-730 and upgrading. Fingers crossed.
oj
Reply to Anonymous
There are 2103 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Dlink dir-600 router problem
By Realbeast, 7 days ago:
In the WiFax router you should turn off the DHCP service and connect its output to the...
Best offers
