Problems after using adware
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I had to run ad aware as my comp had issues, so after that my computer is
gone mental, i cant access start menu, the hourglass stays on, so i cannot
get in 2 anything, is there anyway i can just wipe clean and start again? i
have nothing real important on there
G
Guest
Guest
If it is not that important to you, then yea ust reformat.
(never trust me)
G
Guest
Guest
Sweet how do i do that?
> (never trust me)
john
Splendid
Aug 25, 2003
3,819
Start/Programs/Accessories/System Tools/System Restore
to a date before Adaware was installed.
John
G
Guest
Guest
I cant access my start menu, the hourglass stays as my pointer all the time,
so can't get to it!
Cheers
> John
john
Splendid
Aug 25, 2003
3,819
> so can't get to it!
> Cheers
>>John
How about if you press the Windows key?
G
Guest
Guest
how bout u boot with F8 key held down and choose load with last good restore
point and one before and one before,,, and so on if that doesn't work
then just look in you BIOS and tell it to boot from CD first plug your
Windows CD and boot from it and format install windows fresh.
"John" <John@nowhere.com> wrote in message
news:RB7ie.3261$Vu6.1852@trndny03...
>> time,
>> so can't get to it!
>> Cheers
>> "John" wrote:
>>>>is gone mental, i cant access start menu, the hourglass stays on, so i
>>>>cannot get in 2 anything, is there anyway i can just wipe clean and
>>>>start again? i have nothing real important on there
>>>John
