CMD Startup Problem
Forum Windows XP : Windows XP General Discussion - CMD Startup Problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
When i boot up windows a cmd script appears and shuts down windows.
Virus and adware/spyware scans were made but nothing was picked up. Is
there a solution to this problem?
Andykillz
Andykillz's Profile: http://www.iamnotageek.com/member.php?userid=12805
View this thread: http://www.iamnotageek.com/showthread.php?t=1819072368
Sponsored Links
"Andykillz" <Andykillz.1p48v7@no-mx.forums.iamnotageek.com> wrote in
message news:Andykillz.1p48v7@no-mx.forums.iamnotageek.com...
When you log into Windows, type the following in the Run dialog box to
abort the shutdown
shutdown -a
Then go to msconfig (Winkey+R > msconfig) and disable all the startup
items, then re-enable one start up item at a time and reboot to find the
culprit that is causing the shutdown.
I will give a hint, the startup item in the location /might/ contain
shutdown;
..cmd file, or
..bat file.
Once you find the culprit, post back and someone or myself will tell you
how to delete this startup entry.
William
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > CMD Startup Problem
There are 772 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
