I have a Linksys Cable/DSL Router that give myself and 3 other computer in the house access to the internet.
I recently added another PC to collection (to mess around with) and I also want to hook it up to the Internet via cable modem.
I was told that all I need to do is to buy a switch, hook the switch up to my Cable/DSL Router, and I will be fine. However when I hooked up my 5 port switch, I can't get both of my PC's to see the network. Am I doing something wrong here? Any help would be appreciated.
So you got a router/hub with 3 ports and got a switch for to expand on that?
Do you have the switch hooked up to the router through the uplink port? Not sure if a switch would suite ya best, I've got the same setup but with a hub instead of a switch.
So you are connecting 4 computers to the internet throught your 4-port router.
Quote :
So you will have a total of 5 pcs to hook up.
Quote :
Where are those pcs hooked up? Is it 2/5 that can't access the internet?
If you have an uplink port than hook the switch up to it (with a straigh-thru cable) and hook 2 pcs to your switch and 3 pcs to your router (ports 2,3,4). You can't use the uplink port together with port-1 (either uplink of port-1).
a switch is just a fancy hub (which used to be known as a repeater). The extra feature is not repeating packets indiscriminately out all ports, just the one the MAC address of the destination node is on.
<i>It's always the one thing you never suspected.</i>
what has likely happend is your getting the wrong ip address' make sure your are getting 192.168 address' on all 5 computers. or you hooked the switch up wrong. put the switch on the uplink port on the router and make sure you dont have anything on port one of the router.
i went to the tomshardware forums and all i got was this lousy signature.
