Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade.marketplace (More info?)
So I have a Daytona Twin USA machine. It has always worked flawlessly but
now here is what is going awry:
Start a two player game, and let a fair amount of distance separate each
player - at some point, if the right seat is in front, the map and
everything seems accurate. BUT, the left unit seems to appear to "forget"
that it is participating in a linked race. The marquee is flashing RACE
LEADER for both players. What is even worse, is at the end of the race, it
will say both players finished first.
I am going to start with the re-seating of the cables but I suspect there is
something more to the problem than something that simple. Plus, sometimes,
you can race one time and the problem doesn't happen. I am not sure if the
problem appears more if there is a significant distance between the two
current racers (ie, a player pits) or not. I am suspecting that some link
related hardware needs to be tested and/or repaired.
This is not my realm of specialty. Any advice or suggestions as to where to
start would be most appreciated.
Thanks in advance!
Andy
www.charlottepinball.com/andy.htm
andy@NOSPAMcharlottepinball.com
Please remove NOSPAM to reply directly to me.
Thanks in advance!
Andy
