I have rescently installed a secondary HDD (250gb) since my 40 gig just wasnt sufficient. The new ide cable and drive layout looks like this:
Pri. master : 40 gig (C Pri. slave : dvdrom drive
Sec. master : 250 gig (D Sec. slave : cdrw drive
I am currently running an ati radeon 9800XT (i have a geforce 6800GT, but will not install until i format in 2 weeks, sinc i had driver issues)
My power supply is a superflower real 520W, quad fans, adjustable fan speeds, with 3 main power cables, two with 4x ide power connector + floppy connector, one with 4x ide power connector.
the wire layout goes a little like this:
- one wire powering primary hdd and dvdrom drive
- one wire powering secondary hdd and cdrw drive
- one wire powering radeon 9800XT, 2 case fans, and floppy.
Does this look like a good setup for even power distribution?
Some heavy load games jerk periodically in some places, and the demo "battle of proxycon" in 3dmark03 also stutters. I had this problem a while ago, before installing the new hdd, when i was only using 2 cables, one powering hdd and case fans and floppy, and the other powering the two cdrom drives, radeon 9800xt, and one case fan.
Do you think that the problem i am having now is similar? If so, any tips for remedying the problem? (possibly a new psu with more power?) :/
Thanks for your time
