Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Setting up new network need help!
Forum Wireless Networking : Wireless General Discussions - Setting up new network need help!
Archived from groups: alt.internet.wireless (More info?)
I know this is kind of long, so sorry in advance.
I am setting up a wireless network between a desktop and a new Laptop.
My equipment is:
A DLINK D624 router
An HP desktop connected to the router with ethernet cables
a Toshiba Satellite A40 with built in wireless capability.
So far I have set up the router right out of the box with the defaults
in place.
The wireless connection to the laptop at this point seems to be
working fine.
Next step I took was to enable the MAC filter to block everything but
the MAC addresses of my two machines, still everything seems to be
working good.
Next step I took was to try to enable a 64 bit WEP key. The desktop
connection works great, nothing on the laptop.
The only way to get it working again was to go into the router
settings through the desktop and reset everything to it's default.
I assume I am somehow missing enabling the encryction on the laptop
end but being new to this wireless thing I don't know how to do that.
If my asssumption is right could someone please email this idiot
insructions to do this.
If I am not right what the heck am I missing?
Thank you all in advance
Clueless
Sponsored Links
If you don't have any luck here, try this link:
http://www.broadbandreports.com/forum/dlink
They love to hate the 624
Reply to Tripod
"Ashley Kuehn" <ashkuehn@hotmail.com> wrote in message
news:73fdd22.0404061856.5c894d17@posting.google.com...
> My equipment is:
> A DLINK D624 router
> in place.
> working fine.
> working good.
> Clueless
It would be helpful if you posted what version of the MS O/S.
Duane :)
Reply to Anonymous
> Duane :)
Sorry I am using windows xp home on both machines.
Reply to Anonymous
> working good.
I think the MAC fitering only works for the wireless card to prevent other
wireless cards with their MAC from accessing your wireless network. I don't
think it has ant affect of the wired machine.
You may not be entering the same WEP key on the router and the wireless card
correctly. You should try a simple key first to see if that corrects the
problem, before going to a sophisticated key.
But most likely, the WEP key the was entered by the card's utility or
possibly XP's utility to configure the card did not hold, even though it
looked like it did..
You may want to configure the card using the Device Manager to configure the
card. Right-click My Computer/properties/hardware tab/Device Manager and
find the card. Right-click/properties/Advanced and configure the card there.
You can give that a try.
Duane :)
What I did was not to use the card's utility or XP's utility to configure
the card
Reply to Anonymous
There are 1407 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
