Solved
Help me configure Win 7 for new Rig *new build*
Hey guys,
First off I have a question on relocating my current Windows 7. My laptop that I am using right now has Windows 7 64-bit. I also have a key that has not been used for a 32-bit Windows 7. I want to wipe my laptop and use that key for 64-bit install on my new PC and throw the 32-bit on my laptop. I have both disks ready to install and the keys, will I be able to "re-use" the 64-bit in this manor?
I am getting all my parts in today from newegg to build my new computer. This is my first build so I have a few questions on setting up the software. I bought this MOBO GIGABYTE GA-790XTA-UD4 AM3 AMD 790X SATA 6Gb/s USB 3.0 ATX AMD Motherboard and I have heard through reviews that you need to update the BIOS right away. I don't really know how to do that. I went to the GIGABYTE website and found the latest BIOS update and downloaded it. What do I do with this software once I start up my computer and enter the BIOS?? I am not really sure how to set this up or install Windows 7 from a freshly built PC.
Any suggestions, advice, answers, or direction to other articles would be very helpful because I want to build this PC today and have Windows 7 64-bit up and running :)
Thanks,
Shockem :bounce:
4 answers Last reply Best Answer
More about help configure build
  1. Best answer
    As long as your laptop is running a full retail version of Windows 7, the switch will be possible. However, if your laptop is running an OEM of Windows 7, then your Windows 7 64-bit is permanently tied to your laptop and you will not be able to transfer licensing to the new computer.
    Cheers,
    Cassandra
    Microsoft Windows Outreach
    Cheers,
    Cassandra
    How do I know if it is an OEM or full retail version? I purchased each Windows 7 I have off of the msdnaa website from my school.
    thanks
  3. Hello Shocken,
    When upgrading from Windows Vista to Windows 7 you must upgrade the version currently installed within Windows Vista to the corresponding version in Windows 7. I.E. Windows Vista Home Premium to Windows 7 Home Premium; Windows Vista Business to Windows 7 Professional; and Windows Vista Ultimate to Windows 7 Ultimate. You also cannot upgrade a 32-bit operating system to 64-bit -- to migrate from 32-bit to 64-bit will require a custom install.
    Additionally, you will not be able to "upgrade" from a 32-bit version of Windows 7 to 64-bit -- the architecture between the two is too drastically different to allow such a change. To learn more about the differences between a 32-bit operating system and 64-bit please go to the following link: http://bit.ly/2aT3xP
    I hope that helps you out!
    You can also find lots of information on Windows 7 here in our Springboard website:
    http://technet.microsoft.com/en-us/windows/default.aspx
    Thanks again,
    John M.
    Microsoft Windows Client Support
  4. Best answer selected by shockem.
Laptops Windows 7
