regedit problem
Forum Windows XP : Windows XP General Discussion - regedit problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello,
when i go to the start run dialog box and type regedit it does
not open any more here is what i see
C:\WINNT\system32\regedit.com
The NTVDMCPU has encountered an illegal instruction.
CS:00cf IP0656 OP:fe ae 06 d9 02 choose close
any help would be great i cant figure it out.
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Help- [...] 75125.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1219324
Sponsored Links
Haven't seen this one before, but it makes me wonder if your error is due to
memory access problems.
If so, you can run a diagnostic at http://oca.microsoft.com/en/windiag.asp
But first I would run Disk Cleanup.
Start > All Programs > Accessories > System Tools > Disk Cleanup
Finally, there are some Google 'hits' for similar problems at
http://www.google.com/search?hl=en [...] gle+Search
Good luck.
Michael
"rg123" <UseLinkToEmail@WindowsForumz.com> wrote in message
news:3_1219324_5851721cd0fedbbfccf6367561a3f002@windowsforumz.com...
> Hello,
> request
> Topic URL:
Reply to Anonymous
REGEDIT is an EXE, not COM file and is supposded to be in \windows. (At
least in XP - this is an XP newsgroup afterall.)
> Hello,
> request
> Topic URL:
Reply to Jerry
rg123 wrote:
> Hello,
The real XP registry editor is called REGEDIT.EXE and is located in the
%systemroot% directory (\windows or possibly \winnt) not in system32.
Also Regedit is a 32-bit program and so should not need NTVDM to run.
Unless you have renamed and moved it, I would suspect that you have a virus.
Reply to Anonymous
Good catch guys (Jerry & John). I too don't know why he is referencing a -
non-XP folder for Regedit.
Looks like he may be running Win2k and posted in the wrong forum.
Michael
"Jerry" <NoSpamChiefZeke@MSN.com> wrote in message
news:%23dqC6oXXFHA.3540@TK2MSFTNGP15.phx.gbl...
> REGEDIT is an EXE, not COM file and is supposed to be in \windows. (At
> least in XP - this is an XP newsgroup after.)
>> Hello,
>> request
>> Topic URL:
Reply to Anonymous
From what you have posted, you are not running Windows XP. You need to
figure out what OS you're running, maybe a version of NT? And then find
the appropriate group to address your question.
rg123 wrote:
> Hello,
Reply to Rick
"John Coode" wrote:
> rg123 wrote:
> > Hello,
> it does
> > C:WINNTsystem32regedit.com
> located in the
> %systemroot% directory (windows or possibly winnt) not in
> system32.
> to run.
> have a virus.
i am running win xp home edition and know that it should be an exe
file thats why i posted what i see it doesnt make sense to me was
hoping maybe someone seen before
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1222274
Reply to Anonymous
Did you install XP over Win2K?
news:3_1222274_90c9c1435b1e52f518175c4141e2c9c4@windowsforumz.com...
> "John Coode" wrote:
> > rg123 wrote:
> > > Hello,
> > it does
> > located in the
> > system32.
> > to run.
> > have a virus.
> request
> Topic URL:
Reply to Anonymous
> > "John Coode" wrote:
>  > > rg123 wrote:
>   > > > Hello,
>   > > > when i go to the start run dialog box
> and type regedit
>  > > it does
>   > > > not open any more here is what i see
>   > > > C:WINNTsystem32regedit.com
>   > > > The NTVDMCPU has encountered an illegal
> instruction.
>   > > > CS:00cf IP0656 OP:fe ae 06 d9 02 choose
> close
>   > > > any help would be great i cant figure it
> out.
>  > > The real XP registry editor is called REGEDIT.EXE
> and is
>  > > located in the
>  > > %systemroot% directory (windows or possibly winnt)
> not in
>  > > system32.
>  > > Also Regedit is a 32-bit program and so should not
> need NTVDM
>  > > to run.
>  > > Unless you have renamed and moved it, I would
> suspect that you
>  > > have a virus.
> an exe
> me was
> > request
> standards
> > Topic URL:
> abuse:
nope i didn’t its straight from the box that way windows xp home
edition i think it has something to do with that root directory %
whatever it is but cannot figure it out the computer run fines no
glitches just when i want to open regedit from the run dialog box i
get what i type down there this all happened after my daughter used
the computer so basically i havent a clue as to how it got that way
but none the less although it is operating fine its bothering me
knowing that it isnt right i can acess the registry through the
c:\winnt but shouldnt have to
Reply to Anonymous
"rg123" wrote:
> Hello,
> does not open any more here is what i see
Hi,
I have the same problem..
It’s a laptop with a clean Xp installation.
However, my laptop was infected with w32/Mugly.M a.k.a Picrate.C
and in the description of this virus it is said that it messes with
the access to regedit and some other programs...
I can acces regedit(.EXE) if I access it directly from c:windows, so
the problem is the link, and not the program itself.
Something else; the virus was found in the system32 folder , but when
I search the PC (also hiddenfiles) there is no such folder!!!
I am thinking that, although the virus was removed, the mess it left
is a greater problem to deal with...
Reply to Anonymous
"Spidermomma" wrote:
> Hi,
> It's a laptop with a clean Xp installation.
> Picrate.C
> with the access to regedit and some other programs...
> c:windows, so the problem is the link, and not the program
> itself.
> but when I search the PC (also hiddenfiles) there is no such
> folder!!!
> it left is a greater problem to deal with...
I found my system32 folder (could noy find it with windows explorer,
but total commander did the trick)
found these files:
cmd.com
netstat.com
ping.com
regedit.com
taskkill.com
tasklist.com
tracert.com
I removed them all and all the problems are solved. I also removed the
file file.zip, which was the virus
I also want to say thay both symantec and avg did NOT find the virus,
but pandasoftware did...
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > regedit problem
There are 794 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
