Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
You may be due for an XP Repair Install.
http://www.michaelstevenstech.com/XPrepairinstall.htm
But first I would try the Repair feature in Tweakui (assuming your PC is
working well enough to download/install/run this utility.)
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
After you launch Tweakui select the Repair option (at the bottom of the tree
list).
Select "Rebuild Icons" from the combo box, then click the Repair Now button.
Presumably you have already scanned for viruses and Spyware.
Michael
"mrzepnicki" <choochaloo22@yahoo.com> wrote in message
news:2F5E1142-A7D5-4A99-BB99-3481829AF58F@microsoft.com...
> In safe mode, the desktop icons aren't showing and neither is the task
> bar. I
> can't right-click to do anything and the start menu isn't available to use
> the run command. I'm able to get things 'running', if I use the task
> manager
> and browse through a cd in the drive... all my icons appear and all seems
> to
> be working as normal. I also tried changing the resolution and changing it
> back after reboot with no results, along with the sfc / scannow which did
> nothing at all. I'm about to fix this problem with a 15 foot drop from my
> second floor...
> "Michael T" wrote:
>> So you are saying you are witnessing the same behavior in Safe Mode?
>> Insert WinXP CD-ROM
>> Go to Start > Run and type
>> sfc /scannow
>> Click OK
>> This will at least check the integrity of your system files.
>> Here's a post for someone with a similar problem.
>> 1. Change the screen resolution to 800x600 or some other resolution and
>> the
>> color resolution to 32K colors
>> 2. Reboot the system
>> 3. The icons should now be ok
>> 4. Change the resolution back to the old screen resolution
>> However, I am not too optimistic about this workaround if the desktop
>> icons
>> were missing in Safe Mode.
>> Finally, when you right-click on an unused space on your desktop do get a
>> drop-down menu with "Arrange Icons by" as a selection?
>> If yes, then when you move the mouse cursor over this selection are you
>> able
>> to see that "Show Desktop Icons" is displayed?
>> If none of this helps, you may have to wait for a Microsoft MVP to post a
>> suggestion - as all I think of is to do an XP Repair install. But I
>> really
>> don't think you should have to resort to such a drastic measure.
>> Michael
>> news:9E4F0E9D-FC5E-4A89-9B2D-F8653F3AB16C@microsoft.com...
>> > Still not working. Any other suggestions?
>> > "Michael T" wrote:
>> >> Try Safe Mode - press the F8 key (a few times while XP is booting).
>> >> Then
>> >> try
>> >> Normal mode.
>> >> news:74BE7C45-A3BC-449F-83AE-F655528D5DEE@microsoft.com...
>> >> > After logging in, the desktop appears but none of the icons show, no
>> >> > start
>> >> > menu option, I can't right click but the mouse/cursor is showing and
>> >> > if
>> >> > I
>> >> > go
>> >> > to the task manager, I can start applications with it but still, no
>> >> > desktop
>> >> > icons. I've run tests and all kinds of 'doctors' to see if they'd
>> >> > pick
>> >> > up
>> >> > on
>> >> > a start-up issue but nothing. If anyone has a solution to this, I
>> >> > would
>> >> > be
>> >> > greatly appreciative.
