Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Lost Hard Drive Capacity After System Restore
Forum Windows XP : Windows XP General Discussion - Lost Hard Drive Capacity After System Restore
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
In order to resolve a problem in Outlook, I tried several solutions
recommended by the Microsoft support people. When each of them didn't work,
I did a system restore to return my computer to its original state. After 3
system restores, I noticed that the free space on my hard disk dropped from
94% to 42%. I had not downloaded any new programs and contacted Microsoft
and my computer manufacturer again. They advised me to do spyware scans and
a disk cleanup and defragmenter but that only freed up another 1% of space.
So in one day, I lost 52% of my free space. While I was running the AD-Aware
program, however, I noticed that the program rested for a very long time
(over 10 minutes) on a file called C: System Volume Information\Restore
followed by a whole bunch of numbers. Also, the spyware usually indicates
that approximately 200,000 files have been checked but this time the process
took a very long time and over 400,000 files were checked. I looked for info
on the System Volume Information folder on the web and learned how to bring
this protected folder into view; however, I couldn't open it from the root
directory. It said I didn't have access. Is the problem in this folder? If
I can open this folder, should I delete the files? If this isn't the
problem, where are these new 200,000 files? Please help!!
Sponsored Links
I believe each time you do a "system restore", the system makes a snapshot
(a new restore point) before doing the restore. Also note, your restore
points are stored within the "System Volume Information" folder...
Star Fleet Admiral Q @ your Service!
http://www.google.com
Google is your "Friend"
"Winnipegger" <Winnipegger@discussions.microsoft.com> wrote in message
news:B4457EAD-D88F-4765-AC7C-4DB597E7EE98@microsoft.com...
> work,
> 3
> from
> and
> space.
> AD-Aware
> process
> info
> bring
> If
Reply to Anonymous
My problem is solved thanks to Jupiter Jones.
Reply to Anonymous
- 0 +
GREAT
Now who is Jupiter Jones and what was the fix. There is no message posted
from him.
news:C5F5C601-798D-4FA2-A40C-A00B7F1CB0ED@microsoft.com...
>> work,
>> After 3
>> from
>> Microsoft
>> and
>> space.
>> AD-Aware
>> indicates
>> process
>> info
>> bring
>> root
>> If
Reply to Shakey
Two possibility's.
One is to Adjust the amount of disk space System Restore uses to store
restore points.
http://bertk.mvps.org/html/diskspace.html
And two, would be to purge all the restore points and start over. Then
go back to option one and adjust disk space.
How to Disable and Enable System Restore to purge all restore points.
http://bertk.mvps.org/html/disablesr.html
Regards,
Bert Kinney MS-MVP Shell/User
http://dts-l.org/
shakey wrote:
> GREAT
> no message posted from him.
> wrote in message
>>> several solutions recommended by the Microsoft support
>>> contacted Microsoft
>>> a very long time (over 10 minutes) on a file called C:
>>> System Volume Information\Restore followed by a whole
>>> this isn't the problem, where are these new 200,000
Reply to Anonymous
TO SHAKEY:
I did search of this site and found a post from several months ago. Jupiter
Jones gave the following instructions:
Turn off/on System Restore to delete corrupted files:
Start/All Programs/Accessories/System Tools/System Restore.
Click System Restore Settings on left side.
Check "Turn off System Restore", click OK, follow prompts and reboot.
This deletes ALL Restore Points including corruption.
Then go back and turn on system Restore and create a Restore Point.
It worked and my free space went back to 94% from 42%.
"shakey" wrote:
> GREAT
> from him.
> >> work,
> >> After 3
> >> from
> >> Microsoft
> >> and
> >> space.
> >> AD-Aware
> >> indicates
> >> process
> >> info
> >> bring
> >> root
> >> If
Reply to Anonymous
Hi,
You may find this helpful also.
Keeping System Restore Healthy
http://bertk.mvps.org/html/healthy [...] tDiskSpace
Regards,
http://dts-l.org/
Winnipegger wrote:
> TO SHAKEY:
> months ago. Jupiter Jones gave the following
> instructions:
> Restore.
> and reboot.
> Restore Point.
> "shakey" wrote:
>> GREAT
>>>> contacted Microsoft
>>>> for a very long time (over 10 minutes) on a file
>>>> called C: System Volume Information\Restore followed
>>>> usually indicates
Reply to Anonymous
There are 1272 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
