Being from Nanaimo, check NCIX.COM first to get an idea of basic pricing BC for the parts you're looking for, then branch out to look for the best deals IMO.
I find a great way to start is to see what the white-box builders put in their rigs first, and then decide what's better bang for your buck, and where you think the focus should be. Of course first steps will be choosing CPU/MOBO combinations based on what parts you expect to eventually put in there and upgrade (like PCIe/AGP , DDR/DDR2, etc) from that everything else just fits in those slots. The most importnt thing is not to rush, make sure you're confident with your parts, and their prices. It also doesn't hurt to run the final decision past the forum, even if you get laughs, criticisms, etc. From that you may gleen something you hadn't considered which may make a big difference between satisfaction levels long term.
And last but not least IMO, once you've finally pulled the trigger on a new rig, don't second guess your choices prices, unless you have actual serious problems with your machine or you think you got seriously hosed. No matter what you pick, it's almost guaranteed that there will be something new and better that makes you go 'Awww!' within weeks of your first boot-up.
- You need a licence to buy a gun, but they'll sell anyone a stamp <i>(or internet account)</i> ! - <font color=green>RED </font color=green> <font color=red> GREEN</font color=red> GA to SK
