G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Okay, this is the second MC2000S monitor I've worked on out of a Turbo
with the same problem (and same results). I have no vertical
deflection. The transistors check good and so does R416 @22ohm. I
assume you test a fusible resistor the same way you do any resistor.
I've installed a cap kit and tested every component in the vertical
deflection portion of the chassis. (That is rather easy as it is
surrounded by dashed lines) I've resoldered suspect cold solder joints
on the chassis but have not done all 2000 of them.
Is there something that is a typical failure in this monitor that I
should look for besides the items listed above? I'd really like to get
both of these monitors working.
I see startech journal has a note about deflection problems with this
monitor but I have no subscription to them. If anyone could check their
archives, I would appreciate it.
When I find the item that is causing the problem, I will post the
results here for future reference.
Thanks
Pat D.
Thanks
Pat D.
