Still having network problems!
Last response: in Networking
Okay so I am trying to hookup a Linksys 4 port DSL/Cable Router to a Linsys 5 Port Switch. But am unsucessful.
I'm getting pissed. I went on Linksys' web site to research this issue.
According to the site, I have to plug in the uplink port of the switch to a numbered port of the router...And it should work. It doesn't.
I have tried hooking up the uplink port of the router to a numbered port of the switch. That didn't work either.
I also tried hooking up uplink port to uplink port...Still not working.
Finally I tried hooking up a numbered port on the router straight to a numbered port on the switch (just for the hell of it.), that didn't work.
I have basically tried every combination that I can possibly try. Nothing works. What next? Bad hardware? Any help would be appreciated.
Philippe
More about : network problems
You should be able to connect a number port to uplink port. There is a button on the back of the switch that allows you to set the last port to a uplink or regular port. Did you set it to uplink?
does the switch even work? i would test that before continuing. if you use the uplink port you do not have to use a crossover, a standard patch cable will do. do you have any connectivity at all? check the ips on all the computers. do all this and call me in the morning.
i went to the tomshardware forums and all i got was this lousy signature.
Ask the community
