trouble setting up new machine
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi there,
My old CPU blown up a few weeks ago because of my CPU_FAN
. It was an AMD
Athlon XP 1.33 with a VIA board.
.....anyway... bought a brand new 3000+ Athlon 64 with a Gigabyte GA-K8NS
Ultra-939 and 512 mb of Kinston DDR ram running at 200 mhz...
the problem is when I boot up everything is fine...bios...it beeps, etc, but
when it come to windows XP the thing just reset itself over and over again.
I re-installed Windows, it worked last night but when I came to start it this
morning same thing was happening exept that now I can see the little Windows
XP 'progression loading bar' before it resets...
any ideas ???
thx
Mark
Hi there,
. It was an AMD Athlon XP 1.33 with a VIA board.
any ideas ???
thx
Mark
More about : trouble setting machine
See my answers just below to Soaker. Especially my 2nd post. If Windows is loading up, but fails to fully do so & is freezing or re-starting, then you need to
"Disable automatic restart on system failure".
With a change of motherboard and cpu, the first thing that's usually required is to do is a repair-install of XP.
You said you did a re-install. Do you mean you did a clean install (wiping away the prior o.s.) ?
Did setup of Windows finish OK & completely ?
Maurice N
MVP Windows - Shell / User
Markus wrote:
> Hi there,
. It was
> GA-K8NS Ultra-939 and 512 mb of Kinston DDR ram running at 200 mhz...
> etc, but when it come to windows XP the thing just reset itself over
> and over again. I re-installed Windows, it worked last night but when
> I came to start it this morning same thing was happening exept that
> now I can see the little Windows XP 'progression loading bar' before
> it resets...
> any ideas ???
> thx
> Mark
Maurice N
Markus wrote:
> Hi there,
. It was> an AMD Athlon XP 1.33 with a VIA board.
> it resets...
> any ideas ???
> thx
> Mark
Hi,
I did the repair install like said here:
http://www.michaelstevenstech.com/moving_xp.html
BUT what I did wrong is that I tried to boot up multiple times before doing
so... BUT it was working.. I don't know... it screwed up overnight
?! I've
installed the up-to-date drivers for the integrated sound card... maybe thats
the problem ?!
anyway I'll try your "Disable automatic restart on system failure".. but
once I have the blue screen what do I do ?! take de error message and search
the database ?
hmmm safe mode and last known good configuration doesnt work either
i have a boxed copy of windows XP home edition upgrade for win98
can't wait to go back home and work on it
thx
> Maurice N
> Markus wrote:
> > Hi there,
. It was
> > it resets...
> > any ideas ???
> > thx
> > Mark
Hi,
?! I've installed the up-to-date drivers for the integrated sound card... maybe thats
the problem ?!
the database ?
thx
> Maurice N
> Markus wrote:
> > Hi there,
. It was> > an AMD Athlon XP 1.33 with a VIA board.
> > it resets...
> > any ideas ???
> > thx
> > Mark
When you say "doesn't work", what do you mean? Does it reboot right away? Does it ask for you to login? kindly expand on what exactly happened instead of saying it doesn't work.
See Aumha.org's knowledge base on stop errors and keep it handy
http://aumha.org/win5/kbestop.htm
If a repair install is called for, follow these tips.
Only if you have a "full" XP CD ----
The object of this exercise is to do an in-place upgrade or an in-place installation for purposes of "repair".
It needs to go to the same partition as before , and the same directory as before.
Usually for example XP is on C drive and is on folder/directory \Windows or \WINNT.
Configure your computer to start from the CD-ROM drive. You do that from the pc BIOS setup screen. You specify CDROM as the first drive to boot from.
Insert your Windows XP CD into your CD-ROM drive, and then restart your pc.
When the "Press any key to boot from CD" message is displayed on your
screen, press a key to boot pc from the XP CD.
When you see the following message displayed on the Welcome to Setup screen,
press ENTER:
To setup Windows XP now, press ENTER.
At this point an option to press R to enter the Recovery Console is displayed. Do NOT select this option.
On the Windows XP Licensing Agreement screen, press F8 function key to agree to it.
Make sure that your current installation of Windows XP (in your case, the one you wish to repair) is selected in the box, and then press the R key to repair XP.
Follow the instructions on the screen.
Maurice N
Markus wrote:
> Hi,
> doing so... BUT it was working.. I don't know... it screwed up
> overnight
> integrated sound card... maybe thats the problem ?!
> but once I have the blue screen what do I do ?! take de error message
> and search the database ?
> thx
>> re-starting, then you need to "Disable automatic restart on system
>> failure".
>> Maurice N
>> Markus wrote:
>>> Hi there,
. It
>>> mhz...
>>> when I came to start it this morning same thing was happening exept
>>> that now I can see the little Windows XP 'progression loading bar'
>>> before it resets...
>>> any ideas ???
>>> thx
>>> Mark
press ENTER:
Maurice N
Markus wrote:
> Hi,
> overnight
?! I've installed the up-to-date drivers for the> integrated sound card... maybe thats the problem ?!
> thx
>> failure".
>> Maurice N
>> Markus wrote:
>>> Hi there,
. It>>> was an AMD Athlon XP 1.33 with a VIA board.
>>> mhz...
>>> before it resets...
>>> any ideas ???
>>> thx
>>> Mark
Related ressources
- Trouble Setting Up a Homegroup - Forum
- Help: Trouble setting up first two DC's. - Forum
- Trouble setting up Media Center Channel Guide - Forum
- Trouble with intermittant lockups on new machine - Forum
- Having trouble setting up my new Wireless bridge (Trendnet) - Forum
ok here it is...
when the comp boot up I get to the 'Windows loading screen' but when it's
ready to show the 'login screen', instead it reboot OR I can't even get to
the 'loading screen' OR (like now...) it loads properly and I can use my PC
very weird
I did the proper 'Repair install' 3 times now but it doesn't cure
anything... I tested both my mem sticks and even put my old gforce 2 to try.
It enabled me to go in windows but once I've installed the new driver for my
chipset the comp would freeze on the windows loading screen...put my radeon
back in and now it's working ?! again ?! for how long... is there an utility
to check for hardware issues ?!
i'm thinking of backin everything up on a dvd and just format the
thing...but I'd like not to do it !
thx !
Mark
> press ENTER:
> Maurice N
> Markus wrote:
> > Hi,
> > overnight
> > thx
> >> failure".
> >> Maurice N
> >> Markus wrote:
> >>> Hi there,
. It
> >>> mhz...
> >>> before it resets...
> >>> any ideas ???
> >>> thx
> >>> Mark
ok here it is...
very weirdI did the proper 'Repair install' 3 times now but it doesn't cure
thx !
Mark
> press ENTER:
> Maurice N
> Markus wrote:
> > Hi,
> > overnight
?! I've installed the up-to-date drivers for the> > integrated sound card... maybe thats the problem ?!
> > thx
> >> failure".
> >> Maurice N
> >> Markus wrote:
> >>> Hi there,
. It> >>> was an AMD Athlon XP 1.33 with a VIA board.
> >>> mhz...
> >>> before it resets...
> >>> any ideas ???
> >>> thx
> >>> Mark
thx for the url btw very helpfull !
> press ENTER:
> Maurice N
> Markus wrote:
> > Hi,
> > overnight
> > thx
> >> failure".
> >> Maurice N
> >> Markus wrote:
> >>> Hi there,
. It
> >>> mhz...
> >>> before it resets...
> >>> any ideas ???
> >>> thx
> >>> Mark
> press ENTER:
> Maurice N
> Markus wrote:
> > Hi,
> > overnight
> > thx
> >> failure".
> >> Maurice N
> >> Markus wrote:
> >>> Hi there,
> >>> mhz...
> >>> before it resets...
> >>> any ideas ???
> >>> thx
> >>> Mark
It may well be your video card and the drivers that are the issue ---- given what you've mentioned here.
Whichever card is now working, keep it and don't make quick changes.
Visit the manufacturer's suppoert website. Check to see what the version number & date is for the latest driver for "that" video card is.
Maurice N
Markus wrote:
> ok here it is...
> it's ready to show the 'login screen', instead it reboot OR I can't
> even get to the 'loading screen' OR (like now...) it loads properly
> and I can use my PC
>> P very weird
> to try. It enabled me to go in windows but once I've installed the
> new driver for my chipset the comp would freeze on the windows
> loading screen...put my radeon back in and now it's working ?! again
> ?! for how long... is there an utility to check for hardware issues ?!
> thx !
> Mark
>> in-place installation for purposes of "repair". It needs to go to
>> \Windows or \WINNT.
>> to boot from.
>> your pc.
>> screen, press ENTER:
>> to agree to it.
>> Maurice N
>> Markus wrote:
>>> Hi,
>>> before doing so... BUT it was working.. I don't know... it screwed
>>> up overnight
>>> message and search the database ?
>>> thx
>>>> failure".
>>>> Maurice N
>>>> Markus wrote:
>>>>> Hi there,
. It
>>>>> mhz...
>>>>> beeps, etc, but when it come to windows XP the thing just reset
>>>>> itself over and over again. I re-installed Windows, it worked
>>>>> last night but when I came to start it this morning same thing
>>>>> was happening exept that now I can see the little Windows XP
>>>>> any ideas ???
>>>>> thx
>>>>> Mark
Maurice N
Markus wrote:
> ok here it is...
> and I can use my PC
>> P very weird
> thx !
> Mark
>> \Windows or \WINNT.
>> to boot from.
>> your pc.
>> to agree to it.
>> Maurice N
>> Markus wrote:
>>> Hi,
>>> up overnight
?! I've installed the up-to-date drivers for the>>> integrated sound card... maybe thats the problem ?!
>>> thx
>>>> failure".
>>>> Maurice N
>>>> Markus wrote:
>>>>> Hi there,
. It>>>>> was an AMD Athlon XP 1.33 with a VIA board.
>>>>> mhz...
>>>>> any ideas ???
>>>>> thx
>>>>> Mark
Y W
Maurice N
"Markus" <Markus@discussions.microsoft.com> wrote in message
news:6A165C00-3DC3-4FDD-8495-D7094F743DC9@microsoft.com...
Y W
Maurice N
Related ressources:
- Forumsetting up printer for multiple users on one machine using..
- ForumSetting up file sharing server - help!
- ForumI built a machine for my move to Japan, and I'm having some trouble .
- ForumHaving trouble setting up new wireless router
- ForumSetting up the router for a new machine
- ForumTrouble Setting Up a Minecraft Server
- ForumSetting up two SATA hard drives on an IDE machine
- ForumSetting up 8800 GTX SLI... do i need a new PSU??
- ForumSetting up a network with 2 subnets
- ForumNeed Help setting up a CNC Machine Shop
- ForumNew homebuilt machine not quite cutting the mustard.
- ForumHELP!!! Please with Windows XP
- ForumMachine does not display in "My Network Places"
- ForumI want a lean, mean PC machine!
- ForumMatching an Operating system CD to the machine it was inst..
- More resources
Read discussions in other Windows XP categories
