I am experiencing a strange problem with windows media player videos. All of the video colors are twisted into a strange "rainbow-like" spectrum. I am using a Sapphire Radeon 9800pro with the latest drivers. Here is a link to a picture of what a typical WMV looks like:
http://storage.msn.com/s1pZ8pl_R1n1zHxEmRbtgASGEvmw-UIKc8wZjSHBY4CLPM_UlaDGUVacsxKOJ9r3GINsPKOiaPCRN3z5wz-2mOW-Q/00.jpg?MdToken=759219616336823
Also, here is my DxDiag info:
System Information
Time of this report: 11/5/2004, 21:24:11
Machine name: TIM
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: Award Medallion BIOS v6.0
Processor: AMD Athlon(TM) XP1900+, MMX, 3DNow, ~1.6GHz
Memory: 512MB RAM
Page File: 307MB used, 940MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: /PackageInstall
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: The file ctaud2k.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9800 PRO
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9800 AGP (0x4E48)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1152 x 864 (32 bit) (85Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6483 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/29/2004 08:22:42, 216576 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 9/29/2004 08:22:22, 800256 bytes
Device Identifier: {D7B71EE2-0D08-11CF-E16A-0820A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E48
SubSys ID: 0x00021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy 2 Audio [FF40]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_10021102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0443 (English)
WHQL Logo'd: No
Date and Size: 2/23/2004 15:11:46, 366352 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 60
Static/Strm HW 3D Bufs: 64, 60
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy 2 DirectMusic Synthesizer [FF40], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy 2 Audio [FF40], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 Synth A [FF40] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 Sw Synth [FF40] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 Synth B [FF40] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 MIDI IO [FF40] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 MIDI IO [FF40] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 22:08:42, 57600 bytes
| Driver: usbd.sys, 8/18/2001 12:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/3/2004 22:07:46, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00601102
| | Service: ctgame
| | Driver: ctgame.sys, 12/30/2002 10:53:36, 12160 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 22:14:36, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 21:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
+ Microsoft USB IntelliMouse Explorer 3.0 (IntelliPoint)
| Vendor/Product ID: 0x045E, 0x0047
| Matching Device ID: hid\vid_045e&pid_0047
| Upper Filters: IPFilter
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
| Driver: mouclass.sys, 8/3/2004 21:58:32, 23040 bytes
| Driver: ipfilter.sys, 8/22/2001 22:33:10, 10192 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1.2 GB
Total Space: 6.0 GB
File System: FAT32
Model: MAXTOR 6L040L2
Drive: D:
Free Space: 5.7 GB
Total Space: 12.0 GB
File System: FAT32
Drive: E:
Free Space: 2.6 GB
File System: FAT32
Drive: F:
Free Space: 3.0 GB
Total Space: 8.1 GB
File System: FAT32
Drive: G:
Model: PHILIPS CDRW4012P
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:52, 49536 bytes
System Devices
Name: NETGEAR FA310TX Fast Ethernet Adapter (NGRPCI)
Device ID: PCI\VEN_11AD&DEV_0002&SUBSYS_F0041385&REV_21\3&61AAA01&0&70
Driver: C:\WINDOWS\system32\DRIVERS\Ngrpci.sys, 4.56.0016.0000 (English), 8/17/2001 12:12:20, 32840 bytes
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B099&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/2/2003 04:42:00, 27904 bytes
Name: VIA Tech CPU to PCI Bridge
Device ID: PCI\VEN_1106&DEV_3099&SUBSYS_00000000&REV_00\3&61AAA01&0&00
Driver: n/a
Name: VIA Tech PCI to ISA bridge
Device ID: PCI\VEN_1106&DEV_3074&SUBSYS_00000000&REV_00\3&61AAA01&0&88
Driver: n/a
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1B\3&61AAA01&0&8C
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 23:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:42, 57600 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1B\3&61AAA01&0&8B
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_1B\3&61AAA01&0&8A
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_00000000&REV_06\3&61AAA01&0&89
Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 8/3/2004 21:59:42, 5376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:42, 95360 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00601102&REV_04\3&61AAA01&0&79
Driver: C:\WINDOWS\system32\DRIVERS\ctgame.sys, 5.12.0002.0100 (English), 12/30/2002 10:53:36, 12160 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\3&61AAA01&0&7A
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 22:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 21:58:30, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 21:58:30, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: Creative SB Audigy 2 (WDM)
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_10021102&REV_04\3&61AAA01&0&78
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/3/2004 23:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/3/2004 23:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 22:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 22:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 22:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/3/2004 23:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0444 (English), 2/23/2004 15:16:10, 645360 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0443 (English), 2/23/2004 15:11:46, 366352 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0441 (English), 10/8/2003 10:06:50, 178672 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0441 (English), 10/8/2003 10:08:12, 6096 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0441 (English), 10/8/2003 10:09:10, 130288 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0442 (English), 10/13/2003 17:42:12, 145488 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0446 (English), 2/24/2004 12:17:10, 904784 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.0442 (English), 10/21/2003 17:23:44, 148432 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0003 (English), 3/5/2003 15:07:46, 15840 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 10/21/2003 17:54:50, 217272 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 10/21/2003 17:47:40, 298971 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 10/21/2003 17:47:34, 53932 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.0440 (English), 10/6/2003 14:44:28, 114688 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.0442 (English), 2/18/2004 15:38:32, 585728 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.0440 (English), 10/6/2003 14:46:14, 606208 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 10/21/2003 17:54:48, 140643 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 10/21/2003 17:54:42, 264466 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0000.0005 (English), 2/23/2004 10:10:00, 73728 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 1.82.0000.0001 (English), 6/27/2003 17:51:42, 122880 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0413 (English), 10/14/2003 11:17:56, 332800 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 10/6/2003 14:38:06, 65536 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 14:35:46, 36864 bytes
Name: Promise Technology Inc. Ultra IDE Controller
Device ID: PCI\VEN_105A&DEV_0D30&SUBSYS_4D33105A&REV_02\3&61AAA01&0&30
Driver: C:\WINDOWS\system32\DRIVERS\ultra.sys, 1.00.0507.0001 (English), 8/18/2001 12:00:00, 36736 bytes
Name: RADEON 9800 PRO - Secondary
Device ID: PCI\VEN_1002&DEV_4E68&SUBSYS_00031002&REV_00\4&618BA55&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6483 (English), 9/29/2004 08:22:22, 800256 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6483 (English), 9/29/2004 08:22:42, 216576 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0257 (English), 9/29/2004 07:29:00, 245760 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2494 (English), 9/29/2004 08:18:28, 65536 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0263 (English), 9/29/2004 08:05:10, 2254560 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0033 (English), 9/29/2004 07:45:16, 479840 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0005 (English), 9/29/2004 08:16:22, 81920 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4100 (English), 9/29/2004 07:36:20, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 11:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4107 (English), 9/29/2004 08:16:44, 405504 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4107 (English), 9/29/2004 08:18:08, 90112 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2492 (English), 9/29/2004 08:18:50, 131072 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0010 (English), 9/29/2004 08:18:36, 102400 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2495 (English), 9/29/2004 08:18:20, 30720 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.00.1733.17172 (English), 9/29/2004 10:32:34, 163840 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 9/27/2004 14:38:48, 10055 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.4650 (English), 9/29/2004 08:44:00, 6553600 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4003 (English), 9/29/2004 10:58:44, 294912 bytes
Device ID: PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00\4&618BA55&0&0008
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/18/2001 12:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 12:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/18/2001 12:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 467968 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/18/2001 12:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 23:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/3/2004 23:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/3/2004 23:56:44 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:24 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/3/2004 23:56:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 23:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 23:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 23:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 23:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 23:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 23:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 23:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 23:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 21:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:42 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:38 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:12 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:12 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:12 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 90624 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:46 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:09:58 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMVideo 9 Decoder DMO,0x00600800,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.01.0001.1031
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,1.00.0010.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,1.00.0007.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,1.00.0004.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,1.00.0006.0000
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CT Null Render Filter,0x00200000,1,0,NullRndr.ax,1.00.0001.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.00.0000.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,,
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
EDIROL VSC,0x00200000,1,1,RVI01DX.dll,1.05.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,1.00.0010.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,1.00.0006.0000
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,1.00.0006.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Noise Reduction,0x00100000,1,1,NoisRedu.ax,2.00.0000.0001
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,1.00.0007.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,1.00.0007.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.0785
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,1.00.0005.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
DreamStation DXi2,0x00200000,1,1,DSDXI2.DLL,1.00.0000.0001
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Cakewalk Amp Sim Lite,0x00200000,1,1,AmpSimLite.Ax,10.00.0002.0023
Cakewalk Pitch Shifter,0x00200000,1,1,Pitch.Ax,10.00.0002.0022
Cakewalk Parametric EQ,0x00200000,1,1,ParametricEq.Ax,10.00.0002.0022
Cakewalk Delay,0x00200000,1,1,StereoDelay.Ax,10.00.0002.0022
Cakewalk Chorus,0x00200000,1,1,StereoDelay.Ax,10.00.0002.0022
Cakewalk Flanger,0x00200000,1,1,StereoDelay.Ax,10.00.0002.0022
Cakewalk Reverb,0x00200000,1,1,StereoReverb.Ax,10.00.0002.0022
Cakewalk Time/Pitch Stretch,0x00200000,1,1,stretch.ax,10.00.0002.0022
Cakewalk Buffer Size Matcher,0x00200000,1,1,BufMatch.ax,10.00.0002.0022
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 5.1.1 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
SB Audigy 2 Audio [FF40],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 MIDI IO [FF40],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 Sw Synth [FF40],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 Synth A [FF40],0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Audigy 2 Synth B [FF40],0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
SB Audigy 2 MIDI IO [FF40],0x00200000,2,2,,5.03.2600.2180
SB Audigy 2 Audio [FF40],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy 2 DirectMusic Synthesizer [FF40],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 Sw Synth [FF40],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 Synth A [FF40],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 Synth B [FF40],0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
SB Audigy 2 Audio [FF40],0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: SB Audigy 2 Audio [FF40],0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
SB Audigy 2 Synth A [FF40],0x00200000,11,2,,5.03.2600.2180
SB Audigy 2 Audio [FF40],0x00200000,13,2,,5.03.2600.2180
Any ideas?
System Information
Machine name: TIM
System Model: n/a
Memory: 512MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x1002
Device ID: 0x4E48
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
+ PCI bus
| Service: pci
| | Service: ctgame
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 1.2 GB
Total Space: 6.0 GB
File System: FAT32
Drive: D:
Free Space: 5.7 GB
File System: FAT32
Drive: E:
Free Space: 2.6 GB
File System: FAT32
Drive: F:
Free Space: 3.0 GB
Total Space: 8.1 GB
File System: FAT32
Drive: G:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
Any ideas?
