Archived from groups: rec.games.video.arcade.collecting (More info?)
Hi,
First of all, I'm from Denmark so please bear over with my english skills.
I got a Wells-Gardener K7000 series monitor, which I'm trying to fix. I got
a schematic of the monitor, but I can't seem to find the fault.
The problem is; when it's powered on, nothing happens on the screen. I have
measured the DC voltages, and they are all about 1/5 to small. For example,
the 12VDC is 2.8VDC, the 24VDC is 5.2VDC. If i measure directly on T1 (don't
know what the component is called in english - transformer ? ) I get 10VAC
(on the 12VDC line) and 15VAC ( on the 24VDC line) - so my DC voltages are
all messed up. The B+ is about 145VDC - according to the schematic, it
should be 123VDC - so that must be OK.
The pulses on the base of the HOT (2SD1398) are ok. On collector of the hot,
I measure 400Vpp - isn't that a bit low? When I measure the HOT aout of the
circuit, it's OK from B-E and B-C. Between C-E it's only about 51 ohms - is
that okay ? I can't finde a datasheet on the damn thing.
The flyback capacitors (C36) looks fine. It's 3 capacitors parallel with
eachother.
Any advices what to do or trye ?
Hope I have expressed myself somewhat understandable.
Best Regards Brian
Hi,
eachother.
Best Regards Brian
