I have a Sony VAIO VPCEC3DFX/BJ that is causing trouble for me.
Here is the product link for more details: http://www.circuitcity.com/applications/searchtools/item-details.asp?EdpNo=6700940&SRCCODE=CCLET14ORDER&cm_mmc=Email-_-WebletMain-_-CCLET14ORDER-_-order
The problems are:
- The computer starts to beep (chirping noise) and it freezes/blue screens.
- Every once in awhile when I wake it back up the resolution will be completely messed up, I check on it and it shows that it is correct but I have to restart, or set to a lower resolution then reset to my higher resolution
- The laptop is running hotter than it used to
Sony Support is useless I have tried contacting them before and they had me perform an update which did essentially nothing. Now I am out of their support period and only got 15 minutes which was wasted by them asking generic questions.
Would reinstalling a fresh copy of Windows affect it at all? I have not changed it since the original software it came with.
The problems are:
