First off I know this is the wrong board and I apologize but I got to leave in an hour or so and will be gone for a few days and so I need to order today if possible and don't have the time to wait on the ram board to answer.
Which Ram should I choose
Should I buy one(1) stick of
Kingston HyperX Series 184 Pin 512MB DDR PC-2700
(limit 10 per customer)
- Specifications -
Manufacturer: Kingston
Speed: DDR333(PC2700)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-2-2-5-1T
Support Voltage: 2.6V
Bandwidth: 2.7GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime
and run it in dual channel mode with my current stick of the same ram or buy two(2) of these
You can't run three sticks of RAM in dual channel mode, if you do all of the RAM will revert to single channel mode.
Get ONE stick of Kingston 184 Pin 512MB DDR PC-3200. You can always underclock the new RAM to match the speed of the old RAM, or try overclocking your old RAM to match the speed of the new stuff (doubt that'd work with the picky dual-channel memory controllers tho)
If i put the 3200 in the dual channel with the 2700 hyperx i already have will the 3200 automatically underclock itself? Also i have the asus a7n8x deluxe mobo and i read on another post that i could run them in dual channel dispite their speeds because it runs the ram on individual (pipes?) rather than a single one at 128 or something like that.
(man having an unmonitored computer at work is great)
