Network Login Problem
Archived from groups: alt.internet.wireless (More info?)
For many years my office has had a stable small network (~20 stations) with
a domain server. I recently added a Netgear AP configured to use WPA-PKA
authentication and TKIP encryption. My wireless devices can all access the
network via the wireless node, my problem is with logging into the system.
If the only active network connection to my tablet PC is via the wireless
AP, login usually fails with a message that the network is unavailable and
at logout there is a message that the user's roaming profile could not be
updated because the network drive was inaccessible. I have noticed that
once I log in with a local profile the wireless connection is initially down
but then can be established and I can browse the network, though I have to
authenticate before attaching to a network drive. What's really weird is
that sometimes everything works fine (but just once before usual behavior
reappears)! I have set wireless properties to authenticate as guest if the
computer or user name is unavailable, I have also set the properties to
automatically connect to the AP. I have tried the tablets both with static
IP's and DHCP assigned addresses, all without changing this problem.
Is this normal behavior? If not, is it a configuration problem or a
hardware problem? Also important to know is that the tablets work just fine
with the network and domain server when they are wired.
Thanks for any help here.
JES
2 answers Last reply
More about network login problem
  1. Archived from groups: alt.internet.wireless (More info?)
    You mean a Netgear AP malfunctioning? Yes, it is normal for Netgear
    products to malfunction.
  2. Archived from groups: alt.internet.wireless (More info?)
    I have seen posts flaming Netgear equipment on this board and would not be
    surprised if what I have is a hardware problem. Now... how about a reply
    that really contains some information?
    JES
    "ejmfufhgds" <euenc@cuwl.com> wrote in message
    news:t96c70dmaon6gobnpodvi1kib32spab3cs@4ax.com...
Wireless Login Wireless Networking
