Sign-in / Sign-up
Acer tech help
  • Acer
  • Computer
  • CD-Rom
  • Laptops
Last response: in Laptop Tech Support
September 1, 2012 11:44:55 PM
My ACER computer ate my CD.
More about : acer tech
September 1, 2012 11:52:07 PM
Use an unfolded paperclip to push the manual eject button (little tiny hole).
m
l
September 9, 2012 12:26:49 AM
That's not the problem. The drive opens but the disk is inside the computer.
m
l
September 9, 2012 2:02:39 AM
You may need to completely remove the drive from the laptop. If you flip the laptop over, there should be screw, kinda of by itself, about 5 inches away from the side of the laptop that the DVD/CD Burner is on. Take that screw out (don't lose it), then the DVD/CD Burner should slide out. Use the paperclip to open the drive and retrieve your stuck CD.
m
l
