Help with gateway nv53a
Hello,
I have a gateway nv53a and it says that Windows 7 Build 7601 This Copy of Windows is not genuine. How do i make Windows genuine? Also, the internet won't connect at all, in Device Manager under Other devices it has Ethernet Controller and Network Controller with a yellow triangle and an exclamation point inside of it. Please help.
2 answers Last reply
More about help gateway nv53a
  1. The yellow triangle usually indicates you need a driver for those devices. As for Windows, have you activated it yet?
  2. Download the LAN driver under "LAN" and the atheros wireless lan driver under "wireless lan" from:
    http://support.gateway.com/product/default.aspx?modelId=2375
    as for the windows genuine just google "wga remover" and you will find plenty of stuff to help you
Gateway Laptops
