Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > wireless and wired Ethernet adapters in the same computer
Forum Wireless Networking : Wireless General Discussions - wireless and wired Ethernet adapters in the same computer
Archived from groups: alt.internet.wireless (More info?)
I have a wireless PCMCIA card and a wired ethernet adapter in a Toshiba
laptop that is running Win98.
1. How can I specify which adapter to use by default (I want to switch
between them)?
2. Is there a way in Win98 to set the SSID of the wireless adapter?
I have no manual or specific software for the PCMCIA card it seems.
Remove .NOSPAM from my email address to reply directly.
Sponsored Links
Bob <bob.lockie.NOSPAM@mail.com> wrote in news:f4Fdc.14607$BF2.1248414
@news20.bellglobal.com:
> between them)?
You need to use the route command... or disable one of the adapters.
I believe you need to install the software that came with the wireless
card. Only Windows XP (and maybe 2000) has built in wireless software.
Lucas Tam (REMOVEnntp@rogers.com)
Please delete "REMOVE" from the e-mail address when replying.
http://members.ebay.com/aboutme/coolspot18/
Reply to Anonymous
>between them)?
I have the same set-up. You can run winipcfg and the select the card
that you don't want to use and then release it. I also made (2) batch
files that will release-wireless renew-wired and release-wired
renew-wireless
Reply to Anonymous
> between them)?
You may be able to go to Device Manager and configure the card there. It's
a long shot on a Win 9'x O/S.
Duane :)
Reply to Anonymous
There are 867 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
