Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Conexent Audio Driver issue
Forum Windows XP : Windows XP General Discussion - Conexent Audio Driver issue
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello fellow Windows users. I have a laptop, which I have loaded Win XP Pro
SP2 from scratch before. But recently, i had a hard drive go bad on me. It
went into service and came out with all that extra junk. I wiped it,
downloaded fresh drivers and reinstalled Win XP Pro SP2. This time, the
machine thinks it has ALi drivers for the sound device. This has never
happened before. I tried uninstalling the ALi drivers then running the
Conexent driver setup, but windows thinks the ALi drivers are the best
choice. Is there a way to remove the ALi Drivers from the database? I have
even tried installing the original release of Win XP Pro...that didn't fix
it. there were ALi drivers there as well.
Sponsored Links
go to start/run, and type : devmgmt.msc
Doubleclick the sound device, and see the Driver tab for the button to "Update Driver"
Don't let windows find the driver. Select the manual method.
Mark L. Ferguson
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"KCobra98" <KCobra98@discussions.microsoft.com> wrote in message news:8AECCD4D-E8CB-42D8-9451-3850980431DB@microsoft.com...
Reply to Anonymous
Thanks for your assistance. That method wont work. The drivers for the
device are imbeded into programs that install them. So, once I uninstall the
bad drivers and run the correct driver install, it prompts the computer to
use Plug and Play to install devices. And because windows feel this device
is an ALi device, that is the driver windows installs.
> Mark L. Ferguson
Reply to Anonymous
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
