Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Does anyone know how i can replace the volume icon in the task bar?
When i try to do it through sounds/devices and tick the 'place on taskbar'
box it pops up with the following error
"Windows cannot display the volume control on the taskbar because the Volume
Control program has not been installed. To install it, use Add/Remove
programs in Control Panel.
I don't know where to go as I don't know why it just stopped being in the
task bar.
Please help
Sponsored Links
To repair all system files, go to Start/Run, and type (or paste in): SFC /SCANNOW (see: Description of Windows XP and Windows Server
2003 System File Checker (Sfc.exe): http://support.microsoft.com/defau [...] -us;310747 )
Mark L. Ferguson
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"stacka" <stacka@discussions.microsoft.com> wrote in message news:E87444BD-3703-4527-A0A5-3AF6758E6FB7@microsoft.com...
> task bar.
> Please help
Reply to Anonymous
This behavior can occur if the Sndvol32.exe file is damaged or missing.
See RESOLUTION here...
Volume Icon Is Not Displayed in the Notification Area, and You Receive an
Error Message When You Try to Add It
http://support.microsoft.com/defau [...] US;Q319095
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:E87444BD-3703-4527-A0A5-3AF6758E6FB7@microsoft.com,
stacka <stacka@discussions.microsoft.com> hunted and pecked:
> Volume Control program has not been installed. To install it, use
> Add/Remove programs in Control Panel.
> task bar.
> Please help
Reply to Anonymous
I have the same problem and followed the instructions in the
article,however,I get an error message; "Destination is not a directory:
root\system32\sndvol32.exe."
I tried using "search" and locate the file in the cd,but I cannot copy it
either because file is either "write protected" or "in use"
Help?
Reply to Anonymous
I hope you got the answer to your prob. I had the same and followed Vogels
advise and it worked. I felt like a tech
> task bar.
> Please help
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Volume Control
There are 1060 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
