Tom's Hardware > Forum > Systems > Dell > Need info: Using wireless card with Infinion 8000
Forum Systems : Dell - Need info: Using wireless card with Infinion 8000
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have a Infinion 8000 laptop with built-in ethernet support,
which still runs WinME.
I'm trying to get a wireless network going, but I'm not sure if there's
something wrong or not. When I plug in the wireless card (a 802.11g),
and then proceed to power-up, the laptop beeps once during the
WinME startup sequence (the screen is "black" at the time). The
laptop does indeed come up all the way, but I'm not getting a
wireless connection.
I suspect that the connection issue may still be a configuration
problem (I have a printout of a support answer sheet that suggests
I look at the control panel settings for the wireless card adaptor).
My concern is leaning towards the "beep" -- is this normal?
Thanks,
Bob
Sponsored Links
I guess you install the software to run the wireless card, and I can tell
you that I installed windows xp on a 8000 laptop and the card was
recognized with no problem so it sounds like a driver problem for the card.
<Bob_Myers@raytheon.com> wrote in message
news:OPgZd.2$RE3.0@dfw-service2.ext.ray.com...
> Thanks,
> Bob
Reply to BigJim
There are 1000 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
