I built my new rig last week. As soon as I had it up and running I ran 3DMark03; speed was fine and everything looked great. Then I finished updating everything, including BIOS and nforce drivers using MSI's LiveUpdate utility.
The next time I ran 3DMark I started seeing serious distortion on most of the tests. Both small and large square pixels appearing in narrow vertical bands up and down the screen. This also occurs in the Doom3 demo. I have tried reseating the card, reinstalling the video drivers and flashing back to the original BIOS (1.3) -- no luck. I'm pretty sure it's not a heat or power issue. I'm scratching my head now. I'd be inclined to RMA the card if I hadn't seen it work so well the first time. Anybody have any suggestions? I haven't overclocked anything on the machine, and now I'm progressing into the 'frustrated' stage.
A64 3000 Winchester Stock Speed
MSI Neo2 Platinum
HIS Radeon 9800 Pro Stock Speed
Antec Sonata 380W Truepower
WD160 7200 rpm Hard Drive
Samsung 16x DVD RW
Corsair Value Select 512x2
MSI Neo2 Platinum
Samsung 16x DVD RW
