Battery positive negative
Last response: in Laptops & Notebooks
If you are looking for a new charger, just look at the markings on your old charger.
If you are looking at the battery terminals, don't mess with them. Not all are for power.
You can just use a multimeter on the battery terminals to check the terminals you suspect as the power ones.
Ask the community
