Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > System Idle Process
System Idle Process
Forum Windows XP : General Discussion System Idle Process
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
What is "System Idle Process"? It runs for hours on my computer and grabs
nearly all CPU processing capacity - so slowing everything down. Can it be
given lower priority or (temporarily) disabled?
Reply to Anonymous
Idle - not doing anything, a car idles, xp idles. It is the amount of that
XP has been turned on and the processing power not being used. Look
elsewhere for the problem.
Just my 2ยข worth,
Jeff
__________in response to__________
"DavidN" <holeydollar@hotmail.com> wrote in message
news:578B909C-D531-4B55-BF48-9B23E680D86F@microsoft.com...
> be
Reply to Anonymous
"System Idle Process" is just a filler entry to account for the unused
portion of the CPU's available time.
In other words it is just what it says it is - the percentage of the
time that the system is just sitting there idle doing absolutely
nothing.
Your performance issues are being caused by something else.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Reply to Anonymous
David;
System Idle Process is exactly what it sounds like.
It is the % of processing power you have waiting for something to do,doing
nothing.
If you are having problems, this is not the cause.
Follow this link:
http://www3.telus.net/dandemar/slowcom.htm
Jupiter Jones [MVP]
In memory of our dear friend, MVP Alex Nichol
http://www.dts-l.org
> be
Reply to Anonymous
Break out a dictionary and look up the word "idle," sometime. ;-}
The "System Idle Process" metric is the amount/percentage of time that
your CPU has nothing to do. A reading of 98-99% is generally
considered a good thing, and readings above 90% are normal. Think of
it like a car's engine idling in your driveway before you place the
car in gear.
If your computer is slow, it's because of something else, not the
System Idle Process.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
Reply to Anonymous
There are 2054 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 16 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
