Quiet AGP 6800GT/can you control fan speed on it?
alejandrolanza
30
Hi,
1- I'm about to buy an AGP 6800gt and I'd like to know if anyone has information pertaining which is the quieter 6800gt out there. Reviews/personal feedback are welcome!
2- Can you manually control fan speed on this card? if the answer is yes then #1 becomes a non-issue to me. All I want is for this card to be quiet while not being stressed, I don't care that much if it's loud while gaming.
Thanks!
mozzartusm
Splendid
Sep 17, 2004
4,693
I doubt you will get many answers this time of the day. Give it a little while longer. There is a good review at Anandtech.com it will tell you what you need to know. I have a Leadtek 6600GT and it is quite and well built. I would assume that the 6800 would be the same quality.
