Archived from groups: alt.internet.wireless (More info?)
Netgear MR814V2, firmware is 5.01 (I haven't upgraded yet), Lucent Orinoco
Silver, Windows XP...
The wireless connection drops in and out. Signal strength is "good" and
remains at 11mbps when connected, but randomly drops. I've tried several
channels thinking there may be a neighbor on a 2.4Ghz phone. No help.
Seems to occur when I'm opening half a dozen pages at once, ie, when there's
a bit more network traffic than usual. Then again file transfers don't
necessarily cause it, so who knows.
Basically the connection goes unavailable and shows up as "disconnected" and
then a short (random) time later everything comes right back up. Sitting
two feet from the access point doesn't help either (its not a range or
signal strength issue).
Any ideas?
Thanks.
Any ideas?
Thanks.
