XPSP2 Registry Problem - CLSID clue
Last response: in Windows XP
June 4, 2005 2:25:49 PM
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I'm runing a Pentium 4 2.8G Desktop with 160G HD and 512M RAM.
The machine appears to be working fine, except that any tools that scan the
registry (AD-aware, MS Antispyware, Registry Mechanic, Regedit) cause the
machine to re-boot when a particular CLSID is read.
To try to diagnose this, I've been using Regedit and "Find CLSID". I can
cause a reboot by searching either HKey_Current_User or HKey_Classes_Root.
It always appears to be the same key, but which key remains a mystery,
because the machine reboots!
The machine has been virus scanned using McAfee and Norton AV tools in safe
and normal modes and all all identified Spyware using Adaware, SPybot S&D,
HiJack This removed - bearing in mind I can't do a deep registry scan
because of the re-boot problem.
Any help gratefully received.
Best Regards
Steve
Anonymous
June 4, 2005 2:25:50 PM
Disable automatic restart on system failure (on SP2): Press F8 on restart, and see the menu item to disable auto restart. Restart,
and when the STOP message appears, record information needed for further troubleshooting.
Mark L. Ferguson
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"Steve" <steve.withnell@btinternet.com> wrote in message news:uI51edOaFHA.3864@TK2MSFTNGP10.phx.gbl...
> The machine appears to be working fine, except that any tools that scan the registry (AD-aware, MS Antispyware, Registry
> Mechanic, Regedit) cause the machine to re-boot when a particular CLSID is read.
> To try to diagnose this, I've been using Regedit and "Find CLSID". I can cause a reboot by searching either HKey_Current_User or
> HKey_Classes_Root. It always appears to be the same key, but which key remains a mystery, because the machine reboots!
> The machine has been virus scanned using McAfee and Norton AV tools in safe and normal modes and all all identified Spyware using
> Adaware, SPybot S&D, HiJack This removed - bearing in mind I can't do a deep registry scan because of the re-boot problem.
> Best Regards
> Steve
