6800 Ultra GS getting 2200-2900 in 3DMark05 HELP!
Hey guys
just putting the vid card though it paces and I've found that its doing quite poorly compared to what identical card out there are doing
I've heard of cumfotable OC's getting 4000-4500.
Now I dont really care about getting the best 3DMark score but this to me indicates that something is not right.
Quick spec list
AMD 3000 939 running at 1.8Ghz (200Mhz FSB)
Corsair 4000 Pro mem running at 2.5CL
Gigabyte K8NS Ultra 939
WD Raptor 74GB HD
Gainward 6800 Ultra Gold sample (430/1200)
now first I ran with 66.xx drivers and got 2200ish. then ran with 71.25 driver and got 2700ish and with a small overclock to 445/1245 got to 2900ish
Now while I will overclock the CPU eventually (letting it burn in first) I doubt that the CPU running at 1.8Ghz with HyperTransport @ 2x1000MHz has bottlenecked the card to 2/3rds its speed but then again....
What I really need are some ideas on what might be amiss.
mabe somthing in BIOS ? (AGP is sitting at 66Mhz as normal)
mabe somthign wrong with the card ? (is there any way to check that the card is fully functional e.g. all 16 pipes etc)
Mabe its simple a lack of CPU Ghz which can be fixed with faster base CPU or a good overclock into the 260Ghz FSB (bout 2.2-2.3Ghz CPu final) even that only a % boost and may ahve zero effect on card performance
not sure what else it could be but I do know that 2700 for a top of the line card is prob worse than a 6600 GT.
any advice would help or link to a test program
Yep ya picked it I install the 5.1 driver for nForce and my score hit 5426 @430/1200
wierd coulda swore I'd alread installed them although I did do most of my driver installing around 3am so that might have played a role
Note to self , critical driver install should be done when awake
Hehehe thanks guys hadetn even occured to me to check my nForce drivers (it is my first nForce board after all ;)  )
Related ressources
Yep now I just have to decide what cooling to go with
atm leaning toward NV Silencer 5 , above avg cooling and is nice n quite, and with my nice big 120mm fans in antec case I figure I can get a solid OC with air cooling
any suggestions on a better air cooling solution for this card ?
btw its running at 430/1200 atm with max setting 470/1400 so plenty of room overhead
Ask the community
