Archived from groups: alt.internet.wireless (More info?)
Anyone had this experience? Installed a SMC wireless card on a Compaq
Presario laptop and when IE opens up and is loading pages there is a buzzing
static sound from the speakers even if you mute the volume control. Is
there a fix to this?
Thanks
Found a post regarding this issue. It seems that Compaq built these before
wireless without regard to possible frequency issues - shielding perhaps?
Disabling the sound card will stop it, or possibly using a USB wireless
adapter away from the motherboard may reduce or eliminate the noise.
"Nottoman" <nottoman@hotmail.com> wrote in message
news:a0Tec.24830$F9.19061@nwrddc01.gnilink.net...
buzzing
> Thanks
> before wireless without regard to possible frequency issues -
> shielding perhaps? Disabling the sound card will stop it, or possibly
> using a USB wireless adapter away from the motherboard may reduce or
>> Compaq Presario laptop and when IE opens up and is loading pages
>> there is a buzzing static sound from the speakers even if you mute
>> the volume control. Is there a fix to this?
>> Thanks
This has been discussed from time to time on alt.sys.pc-clone.compaq.
Try Google groups.
