G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Board lights up and sound plays first few bars of intro,then
resets,over and over.Game has worked for last 4 months , no problems
..Changed out power supply(was set at 5.13 vdc)now set at 5.22vdc before
game will power-up with different supply,then reset.
There is no ground wire attached to the power supply from the ac
incoming line,stops at ac filter. problem here? What is the proper
voltage and how high can I set the voltage before I fry the board?
Need your thoughts please . Thanks for the time , Mike
