Archived from groups: alt.sys.pc-clone.dell (More info?)
Today while I was reaching for something on a shelf, I accidentally
bumped my Dell 1901FP flat panel monitor with my hand and it suddenly
went dark, the image replaced by the "digital test" screensaver in a
little box, letting me know that the monitor was not detecting a signal
from the computer. It was really not a very hard bump at all. At the
time of this incident I was running only Internet Explorer and had not
installed anything new for some time. I also do plenty of regular virus
and spyware checks.
Well, I powered everything off (computer and monitor) and then
checked all the cable connections. Then I powered on the computer and
monitor again. The computer booted up fine - after the normal interval
I could hear the Windows greeting music. However, the monitor still
insisted that it was not detecting a signal from the computer. If it's
not the monitor or the cables, does that mean it's a problem with the
video card? Can anyone suggest what I should do now? (I do have an old
monitor I could use for test purposes but it weighs 60 pounds and I'd
really rather not have to lift it onto my desk.)
My system is a Dimension 8300, P4 3 Ghz, 1GB RAM, 120 MB HD (7200
RPM), video card is 128 MB DDR ATI Radeon 9800 PRO. OS is Windows XP
Home, SP2.
> and spyware checks.
> Home, SP2.
I forgot which one it is, but if my memory serves me correctly,
pressing one of the 3 small buttons, on the front of the monitor,
should bring things back to normal.
accidentally
suddenly
a
signal
the
not
virus
> > and spyware checks.
and
interval
it's
the
old
I'd
(7200
XP
> > Home, SP2.
> Notan
D'oh! Yes, that worked. Thank you. My face is very red.
"Hal Terrie" <halterrie@worldnet.att.net> wrote in message news:1111217144.171774.12500@f14g2000cwb.googlegroups.com...
Perhaps I'm missing something, but if hitting the input select made the
digital test screen go away and the video card signal come back, that
makes me think you are connected via analog cable. True? If so, I'm
curious as to why you aren't connecting via DVI.
No problem. The middle button on the lower right corner of the monitor
switches between using the digital input or the analog input.
You probably just accidently hit that button and switched modes.
"hal[remove this]terrie@worldnet.att.net" <halterrie@worldnet.att.net> wrote
in message news:1111213239.145543.118370@f14g2000cwb.googlegroups.com...
> and spyware checks.
> Home, SP2.
> -- Hal Terrie
