Archived from groups: rec.games.video.arcade.collecting (
More info?)
Well here it is a month later, finally looking at this thing.
The 4 rect diodes all measure the std junstions drop in circuit one way
and a reading that rises to approx 1.770 the other way
I'm guessing this is because of the cap.
Are these OK or do I need to take them out of circuit?
If so can I just take the cap out of circuit instead of all the diodes?
d23 measures correctly
d24 measures the junstion drop in both directions
I'm guessing this one is bad, unless it's a "in circuit" thing.
Thanks
Mike
> > Got this game with a dead monitor.
> > Check it out and the monitor board was loose and it had blown a fuse.
> > I remount it and replace the fuse.
> > It's F1 - 1.5A SB.
> > Blows on powerup.
> > typically the fuse is for the flyback.
> > If the board touched the chassis, is there something else that could be
> > blowing the fuse?
> > Does anyone have schematics for this model or is it buried on Bobs page
> > somewhere?
> Check closest to the fuse, rectifier diodes D19 -22. If not that, check
the
> regulator, HOT, retrace cap. If you suspect the flyback, pull the HOT out
of
> circuit, if the fuse still blows it's probably the rectifier diodes. I've
> seen those diodes go bad on their own, but more so from powering the
monitor
> without an isolation xfmr.
