How to replace cmos battery on toshiba satellite m105
It should be as easy as.... Open the case at the bottom (check the smaller access panels first to see if the battery can be accessed without removing the bottom of the case). Remove the battery; it looks like a watch battery, take note of the orientation of the battery. Take battery to local radio shack, Wal-Mart, store that has watch batteries....Get matching battery. Place new battery in, facing the same way as the old one was. Close Case/access panel. Make sure that you are grounded before you touch anything on your board!!!! Static electricity is a killer.
morbious81
124
Hi :)
On most Toshiba laptops of that generation, the cmos battery is NOT beneath an accessible panel....
Its a TOTAL strip down to replace it..... and that not the job for an amateur...take it to a laptop repair shop.... similar to the ones I own....
WHY do you think you need to change the battery anyway ?
All the best Brett :)
