I have installed, and benchmarked the XFX PVT43AND GEFORCE 6600 GT 128MB DDR3 AGP8X W/ DUAL DVI & TV-OUT. (ref url: http://www.buyxg.com/store/item.asp?id=1125&catID=138)
The card is functional but I do seem to be having performance related issues. I feel that the card is stessing to handle what it should be able to.
My system specs are as follows:
550 w psu (vga card calls for 450w)
AMD 64 3200+ (2.2 ghz)
Chaintech motherboard (with AGP v3.0, Fast Write enabled, 8x enabled)
Drivers: Had official Nvidia drivers installed, but had better results with the latest Official Nvidia Beta Drivers
OS: Windows XP Pro x32; Have tried Windows XP 64 RC2 Beta with similar results
nothing is or has been overclocked (powerful enough system in the first place)
The obvious:
1. My score from 3D Mark was 3404 ouchy
2. My GeForce FX5200 performed better on this system (now thats bad) lol
3. The diagnostic applications displayed that I do still have the memory clocks, and memory that the retail stock card should have
4. I have searched the XFX site but it seems to be that this is an extremely nice quality card and I have not found anyone to have complications with it.
The other symptoms:
1. lag in offline games (offline) at a knowticable rate
2. Doom 3 has lines (like glitches rather than lines) on the screen randomly and often. The settings are low compared to what the card should be able to handle. Settings: 1024 resolution; Trilinear; AA off; Vertical Sync off
3. Also experienced similar results in Half-Life 2 with similar settings
4. Within Windows XP: system stutters (small quick lags) when opening windows (mostly)
5. Note: My other card (the GeForce FX5200) does not seem to have so many issues with my current setup as does the 6600 gt
My Questions:
1. The card is functional but is there a possibility that I could have recieved a card with a weak chipset?
2. Is there a possibility that the VGA BIOS feels allergic to my current hardware setup? If so where can I obtain a more recent BIOS for this model?
Any help or advice would be greatly appreciated
Be Well, Marc Casey (marc.casey@gmail.com)
The obvious:
The other symptoms:
My Questions:
